Configuration Tab
The Configuration tab contains the global and configuration-specific model settings and requests of the current model in tree form.
The tree contains a Definitions branch, Global branch and Configuration specific branch.
Figure 1. The Configuration tab in the model tree.
Definitions Branch
The Definitions branch contains by default the predefined variables, media and workplanes. When a named point or cable definition is created, it is added to the Definitions branch.
Global Branch
The Global branch contains the global specific model settings. From the right-click context menu define solver settings, specify the global frequency, sources, loads, networks and power.
Configuration specific Branch
The Configuration specific branch contains configuration specific settings. From the right-click context menu define requests per configuration, frequency per configuration, sources per configuration, loads per configuration and power per configuration.
