Antenna Coupling Using an Ideal Receiving Antenna
Calculate the coupling between a helix antenna and a Yagi-Uda antenna located in front of a large plate. Reduce computational resources by using the uniform theory of diffraction (UTD) and an ideal receiving antenna.
- far field radiation pattern
- far field spherical modes
- near field aperture
- Antenna_Coupling_Helix_Antenna.cfx: Model of the helix antenna used to pre-calculate the three field types that will be used in the ideal receiving antennas.
- Antenna_Coupling_Receiving_Antenna.cfx: Model that calculates the antenna coupling using the ideal receiving antenna types.
- Antenna_Coupling_Full.cfx: Full model for both antennas.
Figure 1. 3D view of the full model.
