Creating the Model
Create the model in CADFEKO. Define any ports and sources required for the model. Specify the operating frequency or frequency range for the model.
- Use the model considered in Pin-Fed, Planar Multilayer Substrate Model and rename the file.
- Copy (duplicate) the patch part from the antenna part.
Delete the antenna part.
The model should now only contain the patch part.
Create the feedline.
Create a rectangle.
- Definition method: Base corner, width, depth
- Base corner: (-lengthX/2, -feedlineWidth/2, 0)
- Width: -lambda/4
- Depth: feedlineWidth
- Label: feedline
Create a rectangle.
- Union all the elements.
- Add a microstrip port at the edge of the feed line.
- Add a voltage source to the port. (1 V, 0°, 50 Ω).
