Microstrip Patch Antenna
Model a microstrip patch antenna using two feed methods (pin feed, microstrip edge feed). The dielectric substrate is considered as a finite substrate and an infinite planar multilayer substrate.
- Pin-fed, finite ground and solved using MoM (SEP).
- Pin-fed, finite ground and solved using the FDTD.
- Pin-fed, infinite substrate and solved using the MoM (planar Green's function for multilayered media).
- Edge-fed, infinite substrate and solved using the MoM (planar Green's function for multilayered media).
The simulation time and resource requirements are greatly reduced when using an infinite plane, although the model is a less accurate representation of the physical antenna.
