Defining Calculation Requests
Define the calculation requests in CADFEKO.
Modify the existing far field request to export spherical modes.
- On the Advanced tab, select the check box Calculate spherical expansion mode coefficients.
- Select the check box Export spherical expansion coefficients to ASCII file.
Create a near field request and export the fields to file.
- Definition methods: Spherical
- Start: (1.3*w_l, 0, 0)
- End: (1.3*w_l, 180, 360)
- Increment: (0, 5, 5)
- Clear the Sample on edges check box.
- On the Advanced tab, select the Export fields to ASCII file check box.
Tip: Sampling on the edges would create duplicate request points at 0° and 360°.
