Navigate the API Documentation
Learn to navigate the API documentation to find the correct syntax for an automation script.
The application programming interface (API) documentation is contained in the Feko User Guide. The integrated help is simple to navigate due to its Back and Forward functionality and the Index or Search tab is useful to find a specific item.
For this example we will make use of the Index tab in the integrated help. For conciseness we will make use of the terminology, search, when we refer to the Look for: box on the Index tab.
Hyperlinks are indicated by blue text. Clicking on a hyperlink will navigate to other sections in the documentation.
The following example illustrates how to navigate the documentation and to use the correct syntax. The example contains steps to create a wire-fed patch antenna on a planar multilayer substrate.
Note:
The model is included in the Feko installation in the following directory:
examples\ExampleGuide_models\Example-I01-Introduction_to_Application_Automation
