Creating a Union of the Substrate and Patch
Create a single geometry part from the different parts through a union.
The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in CADFEKO.
The example considers the reflection coefficient and impedance of a microstrip patch antenna on a substrate modelled on an infinite substrate and then on a finite substrate.
Calculate the input impedance of a microstrip patch antenna close to 2.8 GHz. The substrate is considered as an infinite planar multilayer substrate as it is more resource efficient. The substrate is then modelled as a finite substrate to make it a more realistic model.
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Before starting this example, ensure that the system satisfies the minimum requirements.
Calculate the input impedance of a microstrip patch antenna on an infinite planar multilayer substrate.
Calculate the input impedance of a microstrip patch antenna on a finite substrate. Modify the previous model by removing the infinite planar multilayer substrate and creating a finite substrate.
Create the model geometry using the CAD component, CADFEKO.
Remove the infinite planar multilayer substrate.
Define variables to create a parametric model.
Create a finite substrate by creating a cuboid. Set the region of the cuboid to the medium, substrate.
Change the surface property of the patch to be metallic.
Create a mesh suitable for the geometry and wavelength.
Check the model for any errors before running the Solver to ensure the model is electromagnetically validated.
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated automatically for all voltage and current sources in the model.
Use the existing POSTFEKO session to display the new results.
This example showed the construction, configuration and solution of a microstrip patch antenna. The model was constructed from an infinite substrate and ground plane in the former case, and a finite substrate in the latter case.
The example considers the coupling between a typical monopole antenna and a loaded transmission line above a ground plane.
The example considers the transmission and reflection coefficients of a waveguide power divider.
The example considers the optimisation of the gain of a bent dipole in front of a plate.
