Topics Discussed in Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
- CADFEKO
- Create a monopole using a line. Specify the local wire radius for the monopole.
- Create the transmission line using a polyline.
- Define a ground plane using an infinite ground plane.
- Add a port and voltage source to the monopole.
- Specify the radiated power of the model.
- Add a port and complex load to the transmission line.
- Set the solution frequency. Use adaptive frequency sampling to obtain continuous data.
- Mesh the model.
- Run CEM validate to ensure the model is electromagnetically validated.
- Run the Solver.
- POSTFEKO
- View the simulated input impedance and currents on a graph.
- Change the line colour, marker style, marker colour of a trace on the graph.
- Add shapes (line, arrow, rectangle or circle) to highlight certain areas on the graph.
Altair/2022.0/help/feko/examples/GetStarted_models/Project4-EMC_Coupling/Coupling.cfx
