Creating the Waveguide Sections
Create the waveguide sections using two cuboids.
Create the first cuboid.
- On the Construct tab, in the Create solid group, click the Cuboid icon.
- Create the cuboid using the Base centre, width, depth, height definition method.
- Use the following dimensions:
Dimension Value Base centre (C) (0, 0, 0) Width (W) wg_w Depth (D) 2*wg_w Height (H) wg_h Label Cuboid1 -
Create the second cuboid.
- Create the cuboid using the Base corner, width, depth, height definition method.
Dimension Value Base corner (C) (wg_w/2, -wg_w/2, 0) Width (W) wg_w Depth (D) wg_w Height (H) wg_h Label Cuboid2
