Creating a Cylinder
Create the power dividing pin using a cylinder.
Create a cylinder located at the origin along the Z axis.
- On the Construct tab, in the Create solid group, click the Cylinder icon. On the Create cylinder dialog, select the Base centre, radius, height definition method.
- Create a cylinder using the Base centre, radius, height definition method.
- Set Radius (R) equal to the defined variable, pin_r.
- Set Height (H) equal to the defined variable, wg_h.
Note: Default values are used on geometry creation dialogs to allow a preview of the primitive in the 3D view. You may change the values as required.- Click Create to create the cylinder and close the dialog.
To view the full-length cylinder in the 3D window, zoom the cylinder to the window extent.
Zoom to extents of the 3D view using one of the following
workflows:
- On the View tab, in the Zooming group, click the Zoom to extents icon.
- Press F5 to use the keyboard shortcut.
