Display the calculated near fields in the 3D view. Animate the
instantaneous near field.
Select the 3D View1 window.
Disable the display of symmetry.
On the 3D View
contextual tabs set, on the Display tab, in the
Method display group, click the Symmetry icon.
To view the near field inside the waveguide, enable mesh
opacity.
On the 3D View contextual tabs set, on the Mesh tab, in the Opacity group, click the
Mesh opacity
icon. Select a value of 40% from the drop-down list.
Tip: If a specific opacity value is required, select
Custom from the drop-down list.
On the Home tab, in the
Add results group, click the Near field icon. Select NearField1 from the drop-down list.
Animate the phase of the near field.
In the result palette, on the quantity panel select Instantaneous
magnitude.
On the 3D View
contextual tabs set, on the Animate tab, on the
Settings group, click the Type icon. From the drop-down list, select the
Time step icon.
Start the animation process.
On the 3D View contextual tabs set, on the Animate tab, on the Control
group, click the Play icon.
Stop the animation by clicking the
Play icon again.
