Changing the Waveguide to a Shell Part
Change the solid waveguide part to a shell (hollow) part with metal walls.
The example is intended for users with no or little experience with CADFEKO. It makes use of a completed rectangular horn model to familiarise yourself with model creation in CADFEKO and viewing the simulated results in POSTFEKO.
The example is intended for users with no or little experience with CADFEKO. This example is not an example intended for simulation, but rather to familiarise yourself with model creation in CADFEKO.
The example considers the reflection coefficient and impedance of a microstrip patch antenna on a substrate modelled on an infinite substrate and then on a finite substrate.
The example considers the coupling between a typical monopole antenna and a loaded transmission line above a ground plane.
The example considers the transmission and reflection coefficients of a waveguide power divider.
Calculate the transmission and reflection coefficients of a waveguide power divider.
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
Before starting this example, ensure that the system satisfies the minimum requirements.
Create the model geometry using the CAD component, CADFEKO.
Launch CADFEKO to get started with creating a model.
Set the model unit to millimeters.
Define variables to create a parametric model.
Create the power dividing pin using a cylinder.
Create the waveguide sections using two cuboids.
Create a single geometry part from the two cuboids.
Create a single geometry part from the waveguide and power divider pin.
Add waveguide ports and ensure the ports have the correct orientation.
Add a waveguide source to the first port. Use the fundamental waveguide mode.
Specify the frequency range of interest.
Translate the model to set symmetry to use model symmetry and reduce computational costs.
Add a near field request to calculate the fields on a surface through the centre of the waveguide.
Create the mesh with the correct settings.
Check the model for any errors before running the Solver to ensure the model is electromagnetically validated.
Launch the Solver to calculate the results. No requests were added to this model since impedance and current information are calculated automatically for all voltage and current sources in the model.
Launch POSTFEKO from inside CADFEKO.
This example showed the construction, configuration and solution of a waveguide power divider. The model consists of a hollow cuboidal sections with a cylinder (pin) in the centre. The near field and input reflection coefficient was calculated and displayed.
The example considers the optimisation of the gain of a bent dipole in front of a plate.
