Adding a Near Field Request
Add a near field request to calculate the fields on a surface through the centre of the waveguide.
On the Request tab, in the
Solution requests group, click the
Near field icon.
On the Request near fields dialog, enter the values as
indicated.
Dimension Start End No. of Points U -10 30 32 V -20 20 32 N 0 0 1
Clear the Sample on edges check box.
Note: A near field request on PEC boundaries will result in a warning by the Solver.
- In the Label field, use the default (NearField1).
- Click Create to add the near field request and to close the dialog.
