Topics Discussed in this Example
Before starting this example, check if the topics discussed in this example are relevant to the intended application and experience level.
- CADFEKO
- Define an optimisation search in CADFEKO.
- Run the optimiser (OPTFEKO).
- Add a wire port to a wire segment.
- Specify symmetry to save computational resources.
- Add a voltage source to a wire port.
- Mesh the model.
- Run CEM validate to ensure the model is electromagnetically validated.
- Run the Solver
- POSTFEKO
- View the optimisation results in POSTFEKO.
Altair/2022.0/help/feko/examples/GetStarted_models/Project6-Optimisation_of_a_Dipole/Dipole_Optimisation.cfx.
