Using the Application Macro
Execute the application macro in POSTFEKO to plot characteristic mode quantities on Cartesian graphs.
The results from a single characteristic mode analysis request will be used as input to the macro.
An application macro is a reference to an automation script, an icon file and associated metadata.
The application macro library allows commonly used application macros to be stored in a repository.
A collection of Lua application macros are available to automate repetitive tasks in CADFEKO.
A collection of Lua application macros are available to automate repetitive tasks in POSTFEKO.
This POSTFEKO application macro can be used to plot all the standard parameters that are available after a characteristic mode analysis simulation was performed.
Characteristic mode analysis (CMA) is the numerical calculation of a weighted set of orthogonal current modes that are supported on a conducting surface. The sets of characteristic near fields and far fields associated with these characteristic currents can provide insight into the radiating properties of structures, allowing for a systematic approach to antenna design and placement.
Characteristic mode analysis calculates various parameters of interest. The characteristic mode plotter was developed to plot these parameters, since it can be a tedious task to do this manually for multiple modes.
The characteristic mode analysis plotter application macro is used to plot the various CMA parameters for a simple dipole antenna.
This application macro is used for calculating mean effective gain (MEG) and envelope correlation coefficient (ECC) for a MIMO antenna configuration. The MEG ratio can also be plotted.
The Multiport post-processing application macro allows you to calculate results for changes in the port loading without rerunning the Solver. Results that are supported are far fields, near fields, currents and specific port parameters, for example, the voltage, current and S-parameters of each port.
Plot multiport S-parameter results.
An application macro to tile any POSTFEKO views side-by-side.
This application macro uses the S-parameter data from a Feko simulation to display a coupling matrix for a multi-port scenario.
The characteristic mode synthesis and design application macro is a post-processing application macro that can be used to calculate a weighted sum for the currents, near fields, and far fields requests for specific characteristic modes of interest. The application macro uses a modified version of the modal weighting coefficient (MWC) to use the radiating phase when synthesising the results with the macro.
A collection of smaller POSTFEKO application macro are available, but these macros do not include step-by-step instructions.
A collection of Lua macros are available to automate repetitive tasks where the workflow span both CADFEKO and POSTFEKO.
