Merging the Results Using the GUI
Execute the combine_results_from_cluster.lua in POSTFEKO to merge the results completed from the cluster run.
Open POSTFEKO and run the
combine_results_from_cluster.lua macro.
The Combine results from cluster dialog is shown.
Figure 1. The Combine results from cluster dialog. - Click Browse to navigate to the .xml summary file for the configuration(s).
Click Merge to start a new POSTFEKO session to merge the data.
The Combine data dialog is shown, indicating the merging progress.
Figure 2. The Combine data dialog. -
Complete the process by clicking OK to acknowledge the
messages.
- Once the merged data is stored, the following dialog is displayed. Click
OK to finish the process.
Figure 3. The Combine results from cluster dialog.
View the combined data in POSTFEKO.
The combined results are saved under Stored data.
Figure 4. The combined results are available under stored data in the project browser.
