Setting up the PBS Job Template File
The job template file contains a set of instructions for the PBS cluster. This list of commands is used for each sweep configuration when submitting the runs to the cluster.
An application macro is a reference to an automation script, an icon file and associated metadata.
The application macro library allows commonly used application macros to be stored in a repository.
A collection of Lua application macros are available to automate repetitive tasks in CADFEKO.
A collection of Lua application macros are available to automate repetitive tasks in POSTFEKO.
A collection of Lua macros are available to automate repetitive tasks where the workflow span both CADFEKO and POSTFEKO.
It is possible to convert between the loss tangent and conductivity description of the material losses at a single frequency. This application macro performs the calculation and can be used in CADFEKO and POSTFEKO.
This application macro is used to divide a larger model with many frequency points, and plane wave sources requested in multiple directions into sub-problems with smaller chunked frequencies and incident directions. The sub-problems are executed concurrently on a cluster reducing the run time to solve the larger problem.
The application macro is divided into two parts. The first part in CADFEKO creates the models to submit to a cluster. The second part in POSTFEKO merges the results.
Set up an RCS sweep configuration. The farm_model_to_cluster.lua uses the frequency and incident angle information from plane wave sources in the model to create the sweep.
Execute the Farm model to cluster application macro in CADFEKO to split a model into smaller runs with one frequency and angles of incidence (phi and theta) to a cluster.
Execute the combine_results_from_cluster.lua in POSTFEKO to merge the results completed from the cluster run.
Execute the combine_results_from_cluster.lua from the command line using POSTFEKO to merge the results on a cluster. Use the --configure-script
argument to pass configuration information to the combine_results_from_cluster.lua script.
The farming application macro has limitations on sweep combinations that can be requested for frequency and angle sweeps.
A collection of smaller shared application macros are available, but these macros do not include step-by-step instructions.
#!/bin/bash
# Simple example for a job script for using Altair Feko
# with a queuing system (PBS, ...)
# General settings for PBS
#PBS -l select=2:ncpus=4
#PBS -l walltime=1:30:00
#PBS -k oe
#PBS -V
# General settings for the Altair Feko job
# Point to the Altair Feko installation from the PBS Home directory
cd $PBS_HOME
. ../../opt/altair/2018.2/altair/feko/bin/initfeko
