Creating the HRRP Model
Execute the CF_generate_high_resolution_range_profile.lua application macro in CADFEKO to set up a model to generate the data for a high-resolution range profile.
- Open the Missile_HRRP.cfx in CADFEKO.
The HRRP generation dialog is displayed.
- Under Definition method, select Specify frequency (start, end, number of samples) to set up a high-resolution range profile using start frequency, end frequency and number of frequency samples.
- Enter the Frequency and Down-range parameters (Follow Step 4 to Step 5 in Example 1: Cylinder HRRP for creating an HRRP profile).
Enter a different start angle and end angle for the Phi
or Theta component (following the steps as indicated in
Step 6 and Step 7 in Example 1: Cylinder HRRP for creating an HRRP profile).
Note: Multiple incident angles are required to generate a 2D profile.
- Under Polarisation, enter a value for the Polarisation angle (deg) in degrees to specify the plane wave source information for the polarisation of the plane wave.
- Under Polarisation, deselect Calculate orthogonal polarisations to activate the calculation of both polarisations for the plane wave.
- Click Generate to set up the model for the specific high-resolution range profile.
Run the model.
Tip: Use the “Farm RCS sweep to a cluster” application macro to speed up the simulation by dividing the HRRP model over the frequency and angles of incidence.
