Create a Multiport Lua Settings File
The Multiport post-processing application macro can be configured to use a Lua settings file to define the loading and excitation for each port. This simplifies the procedure for frequent calculations or large multiport setups with many ports.
The Multiport post-processing application macro is dependent on the order in which the configurations are returned from the Lua settings file. It is expected that the configuration tables are in the following order:
  1. Active ports configuration
  2. Non-active ports configuration
  3. Field data configuration
  4. Processing options
The following command should be defined at the end of the Lua settings file.
return {activePortsConfiguration,nonActivePortsConfiguration,fieldDataConfiguration,processingOptions}
Note:
  • The fieldDataConfiguration table is only required for the measurement method of the Multiport post-processing application macro to map the field data to the correct ports.
