Multiport Post-Processing Workflow
The basic workflow of the Multiport post-processing application macro (MultiportPostProcessing.lua) is described.
Figure 1. Post-processing workflow for the Multiport post-processing macro.
- Specify the input file (or files) that will be used to extract the port
information1 using one of the following options:
- Feko model (.fek file)
- Measurement data
- The application macro extracts the S-parameters and the field data (far field and near field).
- Specify the processing options.
- Specify the non-active ports as well as what the load impedance is at these
ports. The following load types are available:
- Point loads that do not connect to other ports. These ports can be
loaded with any of the following:
- Complex loads
- Series RLC circuit
- Parallel RLC circuit
- Short circuit
- Open circuit
- One-port Touchstone (.s1p) file
- A single multiport Touchstone file that contains all the port terminations (ports can be connected through the S-parameter matrix).
- Multiple one-port Touchstone files (one at each port). This option is equivalent to selecting the first option above (point loads) and specifying all point loads via one-port Touchstone files.
- Specify the excitations for the active ports as well as the load
impedance at these ports.The ports can be loaded with any of the following:
- Direct connection
- Complex load
- Two-port Touchstone (.s2p) file
Note: Ports not specified as non-active are assumed to be sources.
- The application macro calculates the new port parameters and field data.
- View the multiport results in POSTFEKO, under Stored data.
Alternatively, you can specify the loading and excitations for each port using a settings file.
