Plot Multiple S-Parameter Traces Macro
Plot multiport S-parameter results.
This POSTFEKO application macro is ideal for plotting multiport S-parameter results, especially for simulations with a large number of ports. The application macro provides the user with the following options:
  • Select which S-parameter configuration to analyse.
  • Select whether to plot the reflection coefficients and/or transmission coefficients for all ports.
  • Set the Y axis to dB.
  • Select to create a new graph or to use the most recently created existing graph.
