Constructing the Spiral Antenna
Create the complementary slotted two-arm spiral antenna in CADFEKO.
- Set the model unit to centimetres.
Create the following variables:
- a = 1.1459 (The spiral growth ratio.)
- r1 = 1 (The base radius of the spiral.)
- r2 = 45/2 (The end radius of the spiral.)
- w = 1.8 (The width of the slot.)
- width = 70 (The width and depth of the conducting plate.)
- n1 = r1/(2 * pi * a)
- n2 = r2/(2 * pi * a)
- n = n2 - n1 (The number of turns.)
- fmin = 150e6 (The minimum frequency.)
- fmax = 900e6 (The maximum frequency.)
- lambda0 = 100 * c0/fmax (A scale factor of 100 to compensate for working in centimetres.)
- meshing = min(lambda0/12, 1.3
w) (The triangle length to be minimum of
or
1.3 × slot width
Create a helix.
- Definition method: Base centre, base radius, end radius, height, turns
- Origin of the helix (C): (0, 0, 0)
- Base radius (Rb): r1
- End radius (Rt): r2
- Height: 0
- Turns (N): n
- Label: Helix1
To add width to the spiral, create a copy (duplicate) of
Helix1.
- Rename the copy to Helix2.
Modify the start radius and end radius:
- Base radius (Rb): r1 + w
- End radius (Rt): r2 + w
Connect the two helices to create a surface (loft).
Select Helix1 and Helix2 and loft
the two curves to create a surface.
Note: Do not select the Reverse orientation check box.
Create half of the feed.
Create a polygon.
- Corner 1: (r1 + w/2, -w/2, 0)
- Corner 2: (0, -w/2, 0)
- Corner 3: (0, w/2, 0)
- Corner 4: (r1 + w/2, w/2, 0)
- Corner5: (r1 + w, 0, 0)
- Label: Polygon1
Create a polygon.
- To ensure mesh connectivity between the feed and helix, union the lofted surface (Loft1) and the feed (Polygon1). The default label for the new union is Union1.
- Simplify Union1 to remove non-essential edges and faces.
Create the second arm of the spiral antenna.
Copy and rotate Union1 by 180° around the N axis.
- Union all parts of the model. Rename the union to Union2.
Create the conductive plate which will contain the complementary slotted spiral
antenna.
Create a rectangle.
- Definition method: Base centre, width, depth
- Base centre (C): (0, 0, 0)
- Width (W): width
- Depth (D): width
- Label:: Rectangle1
Create a rectangle.
Create the spiral slots in the conductive plate.
Subtract Union2 from
Rectangle1.
Rectangle1.
Create the feed wire.
Create a line.
- Start point: (0, -w/2, 0)
- End point: (0, w/2, 0)
Create a line.
Add a wire port to the feed wire.
