Importing an Antenna Array from File Import a custom antenna array from an Antenna Magus generated .xml file. On the Construct tab, in the Structures group, click the Planes/arrays icon. From the drop-down list, select the Import from file icon. Specify the .xml file that you want to import. The custom antenna array is imported.
