Cable Schematic Elements
View the circuit elements that can be added to the cable schematic view.
Icon Name Description
Resistor Add a resistor to the cable schematic view.
Capacitor Add a capacitor to the cable schematic view.
Inductor Add an inductor to the cable schematic view.
Complex load Add a complex load to the cable schematic view.
SPICE circuit Import a SPICE circuit from a file to define the circuit.
Cable general network Import an N-port Touchstone from file to define a general network.
VCVS Add a voltage controlled voltage source (VCVS) to the cable schematic view.
Transformer Add a transformer to the cable schematic view.
Ground Add a ground to the cable schematic view.
Cable port Add a cable port to the cable schematic view. Voltage sources and loads can be applied to cable ports.
Voltage probe Define a voltage probe to measure the voltage between two points and add to the cable schematic view.
Current probe Define a current probe to measure the current at a point and add to the cable schematic view.
