ADAPTFEKO Options
Specify ADAPTFEKO command-line parameters using the GUI.
- Restart analysis number
- This option can be used if the run was discontinued and the temporary files were not deleted. Restart the solution at the number of the first incomplete simulation.
- Delete temporary files
- This option allows you to delete the temporary files created during the ADAPTFEKO run.
