Creating Configuration-Specific Entities
Convert a global entity to a configuration specific entity.
As an example, loads are converted to configuration specific loads, but the steps are similar for converting frequency, sources and power.
  1. In the model tree, click Loads.
  2. From the right-click context menu, select Specify loads per configuration.
    Figure 1. Convert a globally specified load to a configuration specific load.
All loads are converted from a global item to a configuration specific item and copied to all configurations.
Tip: Alternatively, in the model tree click to specify the configuration settings.
