Applying a Metal to a Face
Apply a metal to a face bordering free space or dielectric region.
- Select the face where you want to apply a metal.
- From the right-click context menu, select Properties.
On the Face properties dialog, click the
Properties tab.
Figure 1. The Face properties dialog (Properties tab). - In the Medium drop-down list, select the metal that you want to apply to the face.
- In the Thickness field, enter the metal thickness.
- Click the OK to apply the metallic and to close the dialog.
