CAD (Geometry) Formats for Import
View the supported CAD (geometry) formats that can be imported into CADFEKO and the supported versions.
CADFEKO is based on the Parasolid solid modelling kernel that allows models to be imported and exported from and to the native Parasolid format without any translation.
Since all imported CAD models are converted to a Parasolid format during the import process, importing from other CAD formats may cause unexpected results. Differences in the internal representation used by various CAD formats may cause adjoining surfaces not to line up correctly. This discrepancy is due to tolerance differences. Models that use a numerical representation can cause faults during scaling.
| Formats | File Format | Supported Versions |
| 3Di | .3di | - |
| ACIS | .sat | R1 – 2021 1.0 |
| AutoCAD | .dxf | 2.5 – 2021 |
| CATIA V4 | .model, .session, .exp | 4.1.9 to 4.2.4 |
| CATIA V5 | .CATPart, .CATProduct, .CATShape | V5 R8 to V5–6 R2021 |
| Gerber | Any (standard format .gbr) | Extended Gerber / RS-274X |
| IGES | .iges, .igs | Up to 5.3 |
| ODB++ | .tgz, .tar.gz | - |
| Parasolid | .x_t, .x_b | 9.0.x - 33.0.x |
| Pro / Engineer | .prt, .asm | 16 to Creo 7.0 |
| STEP | .step, .stp | AP203, AP214, AP242 |
| Unigraphics and NX | .prt | 11 - NX 1926 Series |
AutoCAD
- 3D face
- Arc
- Circle
- Ellipse
- Line
- Polyline
- Polyface mesh (3D)
- Point
- Spline
- 3D Solid
- Trace
- Dimensional annotations
Parasolid
Isolated vertices (acorns) are not imported.1 The coordinates are written to the message window and can be created manually should they be required.
