When the mesh contains holes or faulty triangles were deleted, you can add manually a
mesh triangle to the mesh.
Select the model mesh using one of the following workflows:
- In the 3D view, select the relevant mesh
part.
- In the model tree, select the relevant mesh
part.
Note: The selection must be a single mesh part.
On the Mesh tab, in the
Repair group, click the
Create triangle icon.
Figure 1. The Create mesh triangle dialog.
Specify the triangle vertices using point-entry.
Click Create to create the triangle and to close
the dialog.
The triangle is added to the mesh part.
