Requesting Ideal Receiving Antenna (Spherical Modes)
Add an ideal receiving antenna (spherical modes) request to the model.
  1. On the Request tab, in the Solution requests group, click the  Receiving antenna icon. From the drop-down list, select the RX spherical modes icon.
    Figure 1. The Request receiving antenna (spherical modes) dialog.
  2. In the Field data field, specify the field data to be used to define the spherical modes receiving antenna.
  3. In the Position field, specify where the receiving antenna is to be placed.
  4. In the Orientation field, specify the orientation of the receiving antenna.
  5. [Optional] Click the Advanced tab. Select the Include only the scattering part of the field check box to ignore the radiated contribution from impressed sources as well as the contribution from plane wave sources, yielding only the scattered fields.
  6. [Optional] Specify the internal spherical modes approximation method by selecting one of the following:
    • To describe the receiving antenna by relating the coupling between the spherical mode expansions of the radiated and received antenna fields, select Use spherical modes approximation.
    • To describe the receiving antenna by an impressed radiation pattern obtained internally from the spherical mode description, select Use far field approximation.
  7. In the Label field, add a unique label for the request.
  8. Click Create to request the receiving antenna result and to close the dialog.
