Apply an impressed spherical mode excitation based on pre-calculated spherical modes.
The spherical modes are either radiating to infinity or incident onto a structure
(converging on the coordinate system origin).
This excitation option can be used for the synthesis of an arbitrary electromagnetic
field as well as determining the response of a receiving antenna due to the incident
modes.
On the Source/Load tab, in the
Equivalent sources group, click the Spherical modes icon.
Figure 1. The Add spherical modes source dialog.
In the Magnitude scale factor field, specify the scaling
factor.
In the Phase offset (degrees) field, specify the phase
(in degrees) to be added to the phase of the fields.
In the Field data field, specify the field data to be used to define the spherical modes source.
In the Position field, specify where the source is to be
placed.
In the Orientation field, specify the orientation of the
source.
In the Label field, add a unique label for the spherical
modes source.
Click the Create button to create the spherical
modes source and to close the dialog.
