Model Tree
The model tree contains the variables, named points, the model-creation hierarchy, ports and configuration-specific items of the model. The model tree is split between construction and configuration items.
The panel is located below the configuration list and contains a Construct tab and Configuration tab.
Variables, media and named points are listed in both the Construct tab and the Configuration tab to provide quick access. A right-click context menu is available for all items in the model tree. Double-click on an item to open its properties.
