Union
Combine multiple geometry parts into a single part and to ensure mesh connectivity once the geometry is meshed.
Note: Geometry parts that touch, but not unioned, are not physically connected in the
simulation model (except for FDTD where unioning
is not required.)
Unconnected geometry results in invalid meshes (overlapping
or misaligned) that generate errors during the Feko
solution. Unioning geometry ensures that faces occupying the same space are merged into
a single face where solution settings can be applied.When the union of geometry parts fail, first use the Simplify (repair operation) tool on the primitive parts before attempting the union again.
Note: Where the unioning of imported faces look like they form closed regions, but do
not result in new regions, rather use the stitch tool.
