Shortcut Keys
View the shortcut keys available for EDITFEKO for faster and easier operation of EDITFEKO.
Keyboard shortcut keys help you to save time accessing actions that you perform regularly. The shortcut key or key combination is also displayed in the tooltip that is displayed when you hover the mouse over the action on the ribbon.
| Shortcut Key | Description |
| Feko Components | |
| Alt+0 | Run CADFEKO |
| Alt+2 | Run PREFEKO. |
| Alt+3 | Run POSTFEKO. |
| Alt+4 | Run Solver |
| Alt+6 | Run OPTFEKO |
| Alt+8 | Open the Feko terminal. |
| General Editing and Construction | |
| F1 | Edit card in panel. If a panel is already open, open contextual help for the card. |
| Ctrl+A | Select all (text). |
| Ctrl+C or Ctrl Ins | Copy to clipboard. |
| Ctrl+G | Goto line. |
| Ctrl+N | New .pre file. |
| Ctrl+O | Open file. |
| Ctrl+P | Print. |
| Ctrl+Q | Exit. |
| Ctrl+S | Save. |
| Ctrl+V or Shift+Ins | Paste from clipboard |
| Ctrl+X or Shift+Del | Cut to clipboard. |
| Ctrl+Z | Undo. |
| Ctrl+Y | Redo. |
| Alt+C | Comment line(s). |
| Alt+U | Uncomment line(s). |
| Ctrl+F | Find and replace. |
| F3 | Find next. |
| Ctrl+Left Arrow | Move the cursor to the previous word. |
| Ctrl+Right Arrow | Move the cursor to the next word. |
| Home | Move to beginning of line. |
| End | Move to end of line. |
| Ctrl+Home | Move to beginning of file. |
| Ctrl+End | Move to end of file. |
