Variable Editor
The # card presents a list of supported functions and operations. Use this card to calculate the value of the variable as it would be evaluated by PREFEKO at this point.
Figure 1. The # - Define a variable card.
EDITFEKO is a scripting interface for advanced users to construct models using a high-level scripting language, which includes FOR loops and conditional IF-ELSE statements.
View the main elements and terminology in the EDITFEKO graphical user interface (GUI).
The language used to create and modify models in EDITFEKO is the PREFEKO language.
Comments are descriptive text added to the .pre file to help understand and follow the code execution.
The order of the cards in the .pre file specifies the order of the steps during the simulation.
Two card formats are supported namely column-based and colon-separated. This is relevant to users who externally generate Feko input files and can be ignored by users using EDITFEKO to modify the cards.
Variables are parameters that help to create easily adjustable models such as the investigation of structures with varying geometry.
Symbolic variables can contain expressions to calculate specific parameters of the model and have specific syntax requirements.
Arrays provide functionality to allocate a series of numbers to a parameter.
The PREFEKO language includes a number of predefined variables. Generally, these variables remain constant but may be overwritten by re-assignments.
Logical operations are supported and a specific order of precedence is followed.
Various trigonometric, Bessel and miscellaneous functions are built into Feko to help construct geometry, expressions and calculate parameters.
In the PREFEKO language and Feko in general, items in a model are identified by their labels. Operations are performed and electromagnetic properties are applied to the items through their labels.
Conditional statements provide functionality for changing parameters inside a loop, or for a parameter(s) to depend on other parameter(s).
The PRINT command prints strings, numbers and other information to screen or the .out file to display the solution progress and for debugging purposes.
The FILEREAD function reads data from an arbitrary ASCII file.
Symbolic node names or named points can be constructed as either single points or as an array of points. Arrays of points can then be referenced by only specifying the array name. This is useful when a large number of points are required.
Create geometry in EDITFEKO according to the guidelines to ensure that different mesh parts are electrically connected. Meshes can also be imported to create a model.
EDITFEKO has various default settings that you can configure to customise it to your preference.
View the files associated and generated by EDITFEKO.
View the shortcut keys available for EDITFEKO for faster and easier operation of EDITFEKO.
