Viewing the Coordinate System for Anisotropic (3D) Media
Validate your model that contains anisotropic (3D) media, by viewing the principal direction for each medium.
  1. On the 3D View contextual tabs set, on the Mesh tab, in the Rendering group, click the   Orientation icon. From the drop-down list select the  Media (3D) icon.
    Figure 1. The Anisotropic media (3D) settings dialog.
Each region that has an anisotropic (3D) medium applied to is listed on the Anisotropic media (3D) settings dialog.
Note: An anisotropic (3D) medium is applied to a label.
  1. For each region, you can select the Show coordinate system check box to show the coordinate system in the 3D view.
  2. Click OK to close the dialog.
