Use cursors and its cursor table to read and interpret information from a graph.
Place cursors at predefined positions.
Select the graph where you want to read the information on
the graph.
Enable cursors on the graph.
On the Measure tab, in the
Measurement group, click the
Cursors icon.
Add a cursor table to the graph.
Cursor table icon.
Figure 1. A Cartesian graph with cursor table.
Note: The table contains the data for the displayed points as well as the
difference (indicated by B-A).
Tip: If you move the cursor outside of the visible region of a
graph, a handle appears to retrieve the cursor.
Set the cursor position to a predefined position. For example, place the cursor
at the global maximum of the selected trace.
Select the trace where you want to find the global maximum.
Global max icon.
