Exporting Plotted Data to Clipboard or a Text File
Retrieve the plotted trace data and save to file.
- On the graph, select the trace from which you want to export the plotted data.
Export the plotted data using one of the following workflows:
- To export the data to a .dat file, from the right-click context menu select to file (*.dat) and specify the file name.
- To export the data to clipboard, press Ctrl+X.
