Exporting an Image
Export an image of the active view to file.
  1. On the Reporting tab, in the Export Images group, click the   Export image icon.
    Figure 1. The Export image dialog.
  2. Select a view to export.
  3. From the Image format drop-down list, select one of the following:
    • PNG
    • BMP
    • CUR
    • ICNS
    • JPG
    • PBM
    • PGM
    • TIF
    • WBMP
    • WEBP
    • PDF
    • EPS
    • EMF
  4. From the Export size drop-down list, select one of the following:
    • Same as source
    • QQVGA (160x120)
    • QVGA (320x240)
    • VGA (640x480)
    • SVGA (800x600)
    • XGA (1024x768)
    • SXGA (1280x1024)
    • Custom
  5. Click OK.
    The Image export file name dialog is displayed.
  6. In the File name field, specify the file name of the exported file.
  7. In the Save as type, specify the file type of the exported file.
  8. Click Save to export the active view to file and close the dialogs.
