Customising an Overlay Image
Resize, position and orientate an overlay image. Apply opacity to the image.
  1. Position and resize the image
    1. Select the overlay image you want to customise.
    2. Move the image by dragging the image with your mouse.
    3. Resize the image by dragging the resize handles.
    4. To center the image, from the right-click context menu, select Center image.
  2. Set the opacity of the overlay image.
    1. On the Display tab, in the Image group, click the  Opacity icon.
    2. From the drop-down list, select a percentage or use Custom to set a custom percentage.
  3. Change the orientation of static overlay image.
    Note: This option is only available for a static overlay image.
    1. On the Display tab, in the Image group, click the  Rotation icon.
    2. From the drop-down list, select one of the predefined angles or select Custom to enter a rotation angle.
