Generating a Report From a POSTFEKO Report Template
After a report template was defined, create a report using the report template.
- On the Reporting tab, in the Reports group, click the Generate quick report icon.
From the drop-down list, select one of the following
workflows:
- Select an existing defined report template from which to create the report.
- To set up a report template, select Define report template.
