Feko is a comprehensive electromagnetic solver with multiple solution methods that is used for electromagnetic field analyses
involving 3D objects of arbitrary shapes.
The terms, dataset, slice, trace and 3D result, are used extensively in the documentation. Review the definitions
to get a better concept of these definitions.
Display result data on a graph to allow visual interpretation of the data in a human-readable format, as well as to
communicate the results in reports and presentations.
View the simulation data in a 3D view to allow visual interpretation of the data in a human-readable format, as well as to communicate the results
in reports and presentations. The 3D view can also be used to verify that the CADFEKO or EDITFEKO model is correct.
The Solver contains a number of frequency domain solution methods, as well as a time domain solution method. By default, all
simulation results are obtained in the frequency domain, unless explicitly using the time analysis tool in
POSTFEKO to convert the results to the time domain.
With the time analysis tool in POSTFEKO, electromagnetic scattering problems can be analysed in the time domain. The time domain results are obtained
by applying an inverse fast Fourier transformation (IFFT) on the frequency domain simulation results.
POSTFEKO is a useful tool to help analyse and present data in a useful format. It is often required to use the processed results
in a report or presentation. To help make it easier to generate these reports, several tools are available
in POSTFEKO.
Create a POSTFEKO report template when it is required to create consistent reports. The reports are generated from a preconfigured
POSTFEKO report template using styling from aMicrosoft PowerPoint or a Microsoft Word template.
POSTFEKO has a collection of tools that allow you to quickly validate the model, for example, measure distances, measure
angles and finding specific mesh elements.
EDITFEKO is used to construct advanced models (both the geometry and solution requirements) using a high-level scripting language
which includes loops and conditional statements.
Feko offers state-of-the-art optimisation engines based on generic algorithm (GA) and other methods, which can be used
to automatically optimise the design and determine the optimum solution.
CADFEKO and POSTFEKO have a powerful, fast, lightweight scripting language integrated into the application allowing you to create
models, get hold of simulation results and model configuration information as well as manipulation of data and automate
repetitive tasks.
in POSTFEKO.
to create consistent reports. The reports are generated from a preconfigured POSTFEKO report template using styling from aMicrosoft PowerPoint or a Microsoft Word
template.
On the Reporting tab, in the
Reports group, click the Define template icon.
Figure 1. The Define report template dialog.
In the Document typedrop-down list, select one of the following:
MS Word (*.docx *.doc)
MS PowerPoint (*.pptx)
In the Template field, specify the Microsoft template to
be used for the report generation.
Click Next.
Figure 2. The Define report template dialog.
In the Image formatdrop-down list specify the image format.
In the Export sizedrop-down list select the export size of the images used in
the report.
In the table specify the POSTFEKO graph or 3D view for each tag used in the Microsoft template.
Click Next > Done.
Tip: View the report template in the project browser under Report
templates.
[Optional] Modify the report template.
Reports group, click the Modify template icon.
