Rendering Settings for Results
View the display settings for simulation results of far fields, near fields, currents and error estimates.
The result rendering settings are available on the 3D View contextual tabs set, on the
Result tab, in the Rendering group.
Note: Only the rendering settings relevant to the displayed results are enabled. For
example, if there are no near field iso-surfaces displayed, the Colour icon is disabled.
You can apply the rendering options to far fields, near fields, currents and error estimates.
| Icon | Icon text | Description |
| Grid | Overlays a mesh grid on the result. Provides a sense of dimension to the 3D results. | |
| Surface | Show / hide the coloured surface for the result. | |
| Sampling settings | Adjusts the sampling settings for 3D continuous far fields. | |
| Discrete | Removes the interpolated colouring of a surface and uses a predefined set of colours to represent the surface. | |
| Colour | Specify the colour of the 3D near field iso-surfaces. | |
| Offset | Opens the Set display offset dialog for moving the display of the far field origin. | |
| Opacity | Specify the amount of transparency. | |
| Size | Scale the display of the far field. | |
| Extrusion | Specify the extrusion for near field surfaces. |
