Altair Feko  2022 Documentation
  1. Home
  2. POSTFEKO
  3. Quick Tour of the POSTFEKO Interface
    View the main elements and terminology in the POSTFEKO graphical user interface (GUI).
  • Release Notes
  • Get Started
  • Examples
  • Introduction to Feko
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
  • Feko Solution Methods
  • Optimisation in Feko
  • Feko Utilities
  • Description of the Output File of Feko
  • Feko Application Macros
  • Scripts and Application Programming Interface (API)
  • Appendix
Index
  • Release Notes
  • Get Started
  • Examples
  • CADFEKO
  • POSTFEKO
    • Introduction to POSTFEKO
      Use POSTFEKO to validate meshed geometry and analyse and post-process results.
    • Quick Tour of the POSTFEKO Interface
      • Quick Access Toolbar
        The quick access toolbar is a small toolbar that gives quick access to actions that are often performed.
      • Ribbon
        The ribbon is a command bar that groups similar actions in a series of tabs.
      • Project Browser
        The project browser is a panel that lists the models loaded in the current project, imported data, stored data and scripted data.
      • Model Browser
        The model browser is a panel that organises the model information of the selected model in the project browser, into two separate tabs.
      • Details Browser
        The details browser is a panel that shows in-depth detail for the selected item in the model browser.
      • Status Bar
        The status bar is a small toolbar that gives quick access to general display settings, tools, and graph cursor settings.
      • 3D Views and Graphs
        3D views are used to display mesh, solution settings and interact with the model as well as view 3D results. Graphs are used to display 2D results.
      • Result Palette
        The result palette is a panel that gives access to options that control the data in the 3D view or graph.
      • Help
        The Help icon provides access to the Feko documentation.
      • Search Bar
        The search bar is a single-line text field that allows you to enter search terms and find relevant information in the GUI or the documentation.
      • Application Launcher
        The application launcher toolbar is a small toolbar that provides quick access to other Feko components.
      • Application Menu
        The application menu is similar to a standard file menu of an application. It allows saving and loading of models, print functionality and gives access to application-wide settings.
      • Scripting
        Use the application programming interface (API) to control CADFEKO from an external script.
    • Preferences
      POSTFEKO has various default settings that you can configure to customise it to your preference.
    • Rendering Options
      A number of rendering options are available to ensure that 3D models and graphs (containing a large number of sample points) are rendered efficiently.
    • Model and Project Basics
      You can add a model, open an existing project and save the project.
    • Data Import
      Import text files, native data files and Touchstone format files.
    • Data Export
      POSTFEKO supports the export of native file formats. These files can be exported to use in other sessions or when further post-processing is required.
    • Terminology
      The terms, dataset, slice, trace and 3D result, are used extensively in the documentation. Review the definitions to get a better concept of these definitions.
    • Graphs (Cartesian, Polar and Smith Charts)
      Display result data on a graph to allow visual interpretation of the data in a human-readable format, as well as to communicate the results in reports and presentations.
    • Cartesian Surface Graphs
      A Cartesian surface graph is a flat colour plot with results plotted against two independent axes.
    • 3D Views
      View the simulation data in a 3D view to allow visual interpretation of the data in a human-readable format, as well as to communicate the results in reports and presentations. The 3D view can also be used to verify that the CADFEKO or EDITFEKO model is correct.
    • Frequency Domain Results
      The Solver contains a number of frequency domain solution methods, as well as a time domain solution method. By default, all simulation results are obtained in the frequency domain, unless explicitly using the time analysis tool in POSTFEKO to convert the results to the time domain.
    • Time Domain Results
      With the time analysis tool in POSTFEKO, electromagnetic scattering problems can be analysed in the time domain. The time domain results are obtained by applying an inverse fast Fourier transformation (IFFT) on the frequency domain simulation results.
    • Animation
      Use animation to obtain a better understanding of results or export the animation to use in a presentation or report.
    • Generating Reports
      POSTFEKO is a useful tool to help analyse and present data in a useful format. It is often required to use the processed results in a report or presentation. To help make it easier to generate these reports, several tools are available in POSTFEKO.
    • Lua Scripting
      Feko provides a powerful scripting language that allows you to create scripts that control CADFEKO and POSTFEKO.
    • Tools
      POSTFEKO has a collection of tools that allow you to quickly validate the model, for example, measure distances, measure angles and finding specific mesh elements.
    • Files Generated by POSTFEKO
      View the files associated and generated by POSTFEKO.
    • Shortcut Keys
  • EDITFEKO
  • Feko Utilities
  • Appendix
  1. Home
  2. POSTFEKO
  • Release Notes
  • Get Started
  • Examples
  • CADFEKO
  • POSTFEKO
  • EDITFEKO
  • Feko Utilities
  • Appendix
Index
Figure 1. The POSTFEKO window.
  1. Quick Access Toolbar
  2. Ribbon
  3. Project Browser
  4. Model Browser
  5. Details Browser
  6. Status Bar
  7. 3D Views and Graphs
  8. Result Palette
  9. Help
  10. Search Bar
  11. Application Launcher
  12. Application Menu
  • Ribbon
  • Project Browser
  • Model Browser
  • Details Browser
  • Status Bar
  • Result Palette
  • Help
  • Search Bar
  • Application Menu
  • Scripting
