Designate the tool or surface(s) and on your model for the top pad.
The top pad is attached to the top die with a spring or
hydraulic cushion. The top pad grips the blank against the bottom die in order to
maintain the proper positioning and avoid distortion of the blank during a forming
operation. The configuration also involves selecting a top die to which the top pad
attaches.
From the tool set of an operation, select the Top
Pad.
On the guide bar, choose Part or
Surfaces.
If you choose Part, on the model, select an option from
the table below based on your desired result, and then click to confirm.
If you choose Surfaces, on the model, select the
surface(s) you want to designate as the top pad, and then click to
confirm.
Note: If you modify the blank thickness, you must reconfigure the tools created
by offset.
In the microdialog, click the option to apply a Force or
maintain a Gap. For force, type in a value for the
Initial Force and the Final Force, or click the Calculate the Medium
Force button
Note: The gap value is the material thickness plus 20%.
Define the stroke, velocity, and Coulomb friction coefficient.
In the microdialog, to set the stroke value to the closed position of
the tools, select
. To specify a value, select the pencil tool
, type in a value, and press Enter.
Note: If you define the stroke value to be larger than the
auto-calculated or closed position, the open position of the tool
automatically repositions to match the stroke value to prevent a
collision with the bottom die.
To define the Coulomb friction coefficient, in the microdialog, enter a
value next to the icon
Click to confirm.
On the guide bar, click Attach Tool. The preselected top
die is highlighted. Click to confirm or select a different top die.
Click to confirm the configuration of the top pad.
