CONVERGENCE_CHECK_PARAMETERS
Specifies the parameters for fine tuning convergence checking.
AcuSolve Command
CONVERGENCE_CHECK_PARAMETERS {parameters}
Qualifier
This command has no qualifier.
pressure_residual_check or pres_res (enumerated) [=standard]
Modifies the convergence check of the residual ratio of the pressure equation.
none
Performs no convergence check.
standard or full
Performs convergence check as is.
looser_by_10 or loose_10
Loosens the convergence check by a factor of 10.
looser_by_100 or loose_100
Loosens the convergence check by a factor of 100.
looser_by_1000 or loose_1000
Loosens the convergence check by a factor of 1000.
tighter_by_10 or tight_10
Tightens the convergence check by a factor of 10.
tighter_by_100 or tight_100
Tightens the convergence check by a factor of 100.
tighter_by_1000 or tight_1000
Tightens the convergence check by a factor of 1000.
pressure_solution_increment_check or pres_sol (enumerated) [=looser_by_10]
Modifies the convergence check of the solution increment ratio of the pressure equation.
none
standard or full
velocity_residual_check or vel_res (enumerated) [=standard]
Modifies the convergence check of the residual ratio of the velocity equation.
none
standard or full
velocity_solution_increment_check or vel_sol (enumerated) [=looser_by_10]
Modifies the convergence check of the solution increment ratio of the velocity equation.
none
standard or full
temperature_residual_check or temp_res (enumerated) [=standard]
Modifies the convergence check of the residual ratio of the temperature equation.
none
standard or full
temperature_solution_increment_check or temp_sol (enumerated) [=looser_by_10]
Modifies the convergence check of the solution increment ratio of the temperature equation.
none
standard or full
radiation_residual_check or rad_res (enumerated) [=none]
Modifies the convergence check of the residual ratio of the radiation equation.
none
standard or full
radiation_solution_increment_check or rad_sol (enumerated) [=looser_by_10]
Modifies the convergence check of the solution increment ratio of the radiation equation.
none
standard or full
species_residual_check or species_res (enumerated) [=standard]
Modifies the convergence check of the residual ratio of the species equations.
none
standard or full
species_solution_increment_check or species_sol (enumerated) [=looser_by_10]
Modifies the convergence check of the solution increment ratio of the species equations.
none
standard or full
field_residual_check or field_res (enumerated) [=standard]
Modifies the convergence check of the residual ratio of the phase-field transport equation.
none
standard or full
field_solution_increment_check or field_sol (enumerated) [=looser_by_10]
Modifies the convergence check of the solution increment ratio of the phase-field transport equation.
none
standard or full
levelset_residual_check or ls_res (enumerated) [=looser_by_10]
Modifies the convergence check of the residual ratio of the level set transport equation.
none
standard or full
levelset_solution_increment_check or ls_sol (enumerated) [=looser_by_100]
Modifies the convergence check of the solution increment ratio of the level set transport equation.
none
standard or full
redistancing_residual_check or rdist_res (enumerated) [=looser_by_100]
Modifies the convergence check of the residual ratio of the level set sharpening equation.
none
standard or full
redistancing_solution_increment_check or rdist_sol (enumerated) [=looser_by_100]
Modifies the convergence check of the solution increment ratio of the level set sharpening equation.
none
standard or full
turbulence_residual_check or turb_res (enumerated) [=looser_by_10]
Modifies the convergence check of the residual ratio of the turbulence equation.
none
standard or full
turbulence_solution_increment_check or turb_sol (enumerated) [=looser_by_100]
Modifies the convergence check of the solution increment ratio of the turbulence equation.
none
standard or full
transition_residual_check or ttm_res (enumerated) [=looser_by_100]
Modifies the convergence check of the residual ratio of the transition model equations.
none
standard or full
transition_solution_increment_check or ttm_sol (enumerated) [=looser_by_1000]
Modifies the convergence check of the solution increment ratio of the transition model equations.
none
standard or full
viscoelastic_stress_residual_check or vest_res (enumerated) [=standard]
Modifies the convergence check of the residual ratio of the viscoelastic stress equation.
none
standard or full
viscoelastic_stress_solution_increment_check or vest sol (enumerated) [=looser by 10]
Modifies the convergence check of the solution increment ratio of the viscoelastic stress equation.
none
standard or full
topology_pressure_residual_check or topo_pres_res (enumerated) [=standard]
none
standard or full
topology_pressure_solution_increment_check or topo_pres_sol (enumerated) [=looser_by_10]
none
standard or full
topology_velocity_residual_check or topo_vel_res (enumerated) [=standard]
none
standard or full
topology_velocity_solution_increment_check or topo_vel_sol (enumerated) [=looser_by_10]
none
standard or full
mesh_displacement_residual_check or mesh_res (enumerated) [=none]
Modifies the convergence check of the residual ratio of the mesh displacement equation.
none
standard or full
mesh_displacement_solution_increment_check or mesh_sol (enumerated) [=looser_by_100]
Modifies the convergence check of the solution increment ratio of the mesh displacement equation.
none
standard or full
electric_potential_residual_check or elec_p_res (enumerated) [=looser_by_10]
Modifies the convergence check of the residual ratio of the charge conservation equation.
none
standard or full
electric_potential_solution_increment_check or elec_p_sol (enumerated) [=looser_by_10]
Modifies the convergence check of the solution increment ratio of the charge conservation equation.
none
standard or full
This command specifies a set of factors useful for fine control over convergence checking of various residual and solution increment ratios.
The time stepping, stagger iteration and nonlinear iteration loops check for the convergence of the solution; see TIME_SEQUENCE command for a description. The convergence check is performed on the residual and solution increment ratios of each equation in the problem. For the residual, the ratio of the residual norm over the norm of the forces of the systems is used. For the solution increment, the ratio of the solution increment norm over the solution norm is used. These ratios are computed separately for each solution field, such as pressure, velocity and temperature.
Each iteration loop defines a single convergence tolerance for both residual and solution increment ratios of all equations. The CONVERGENCE_CHECK_PARAMETERS command is then used to globally change the relative importance of one measure over another. As an example, consider a steady laminar flow problem with the following setup:
TIME_SEQUENCE {
   convergence_tolerance               = 1.e-3
   pressure_residual_check             = standard
   pressure_solution_increment_check   = none
   velocity_residual_check             = standard
   velocity_solution_increment_check   = looser_by_10
Steady state is declared when the pressure and velocity residual ratios are below 10-3 and the velocity solution increment ratio is below 10-2 . The pressure solution increment ratio is ignored.
The default parameters of the CONVERGENCE_CHECK_PARAMETERS command are chosen based on experience. You rarely need to change them.
