AcuOdb
Translates AcuSolve data to Abaqus CAE in ODB format.
acuOdb [options]
AcuSolve Post-Processing Program
The results of AcuSolve are stored using an internal format in a number of files in the directory specified by the working_directory option, ACUSIM.DIR by default, and in binary by default. AcuOdb is used to gather and translate these results into Abaqus CAE in ODB format for post-processing or visualizing by Abaqus products. This program is similar to AcuTrans, and the options have the same meaning.
The nodal_output_vars and extended_nodal_output parameters are the same as in AcuTrans; see that command for more details.
In the following, the full name of each option is followed by its abbreviated name and its type. For a general description of option specifications, see Command Line Options and Configuration Files. See below for more individual option details:
- help or h (boolean)
- If set, the program prints a usage message and exits. The usage message includes all available options, their current values and the source of their current values.
- problem or pb (string)
- The name of the problem is specified via this option. This name is used to build internal file names and to generate output files. All generated output files start with the problem name.
- working_directory or dir (string)
- All internal files are stored in this directory. This directory does not need to be on the same file system as the user-supplied input files.
- run_id or run (integer)
- Number of the run in which the translation is requested. If run_id is set to 0, the last run in the working directory is assumed.
- time_steps or ts (string)
- Comma-separated list of time steps to be translated. The comma-separated fields have the general
range format beg:end:inc, where :end:inc and
:inc are optional. beg specifies the first
time step in the range. It may be either a given time step, as specified by
a number, the letter F (or f) requesting the first available time step, or
the letter L (or l) requesting the last available time step.
end is the last time step in the range. It may be either
a time step number or L (or l) requesting the last available time step. If
end is missing, the range is assumed to simply represent
a single time step, that is, end=beg and
inc=1. inc is the increment that ranges from
beg to end. It may be either a number or
the letter A (or a) requesting all available time steps in the range. If
:inc is missing, it is assumed to be one. The range may
also be specified by the single letter A (or a), requesting all available
time steps. This is equivalent to F:L:A. time_steps is
used only for nodal data and is ignored for time series data. Examples of
time_steps option include:
acuOdb -ts 35 # step 35 acuOdb -ts 35,33,37 # steps 33, 35, and 37 acuOdb -ts 33:37:2 # steps 33, 35, and 37 acuOdb -ts 35,33:37:2,37 # steps 33, 35, and 37 acuOdb -ts 33:37 # all steps from 33 to 37 acuOdb -ts 33:37:A # available steps from 33 to 37 acuOdb -ts F:L:A # all available steps acuOdb -ts A # all available steps
- ignore_missing_steps or imts (boolean)
- If set, missing requested time steps are ignored. Otherwise, if the requested time step does not exist, the command issues an error message and exits.
- ignore_missing_variables or imv (boolean)
- If set, missing requested variables are ignored. Otherwise, if the requested variable does not exist, the command issues an error message and exits.
- mesh_output or mesh (boolean)
- If set, the problem mesh is translated.
- nodal_output_vars or outv (string)
- Comma-separated list of nodal output variables to be translated. The list may include:
Table 1. Variable (abbr) Fields Description node_id (node) 1 User-given node number coordinates (crd) 3 Nodal coordinates velocity (vel) 3 Velocity vector pressure (pres) 1 Pressure temperature (temp) 1 Temperature incident_radiation 1 Incident radiation species (spec) nSpecs Species field nFields Field values. For multi_field = levelset and multi_field= algebraic_eulerian, the field values correspond to volume fractions, and are named as volume_fraction-"fieldname". eddy_viscosity (eddy) 1 Turbulence eddy viscosity kinetic_energy (tke) 1 Turbulence kinetic energy eddy_frequency (tomega) 1 Turbulence eddy frequency sqrt_eddy_period (tg) 1 Inverse of square root of eddy frequency dissipation_rate (teps) 1 Turbulence dissipation rate intermittency (tintc) 1 Turbulence intermittency transition_re_theta (treth) 1 Critical momentum thickness Reynolds number surface_y_plus (yp) 1 y+ on turbulence walls surface_film_coefficient (film) 1 Convective heat transfer coef. on turbulence walls wall_shear_stress (wall_shear) 3 Wall shear stress on turbulence walls mesh_displacement (mesh_disp) 3 Mesh displacement vector mesh_velocity (mesh_vel) 3 Mesh velocity vector where nSpecs is the number of species as given in the EQUATION command in the input file. Note that the problem must contain the requested variable in order for it to be translated. For example, the parameter turbulence in the EQUATION command must be set to a value other than none in order for eddy_viscosity to be available. The list of variables is sorted in the order given in the above table. If nodal_output_vars is set to _all, all available variables are translated. The surface_y_plus and surface_film_coefficient are non-zero only on surface nodes given by TURBULENCE_WALL, or alternatively by SIMPLE_BOUNDARY_CONDITION of type wall. Note that the surface_film_coefficient is computed even if there is no temperature equation. However, all relevant fluid material models must include specific heat and conductivity models.
- extended_nodal_output or extout (boolean)
- Extended nodal output flag. If set, adds to the nodal_output variable list
available variables from running_average_output,
time_average_output,
derived_quantity_output,
surface_output,
radiation_surface,
solar_radiation_surface,
output_nodal_residual,
output_error_estimator, and
time_average_error_estimator. The nodal projections
of miscellaneous element quantities and gradients of available field
variables are also added to the list. Those variables defined only on a
subset of the nodes, such as surfaces, are set to zero on the rest of the
nodes. The list may include:
Table 2. Variable (abbr) Fields Description grad_velocity (grad_vel) 9 Gradient of velocity vector grad_pressure (grad_pres) 3 Gradient of pressure grad_temperature (grad_temp) 3 Gradient of temperature grad_field 3*nFields Gradient of field values. For multi_field = levelset and multi_field = algebraic_eulerian, the grad field values correspond to grad volume fractions, and are named as grad_volume_fraction-"fieldname". grad_species (grad_spec) 3*nSpecs Gradient of species grad_eddy_viscosity (grad_eddy) 3 Gradient of turbulence eddy viscosity grad_kinetic_energy (grad_tke) 3 Gradient of turbulent kinetic energy grad_eddy_frequency (grad_tomega) 3 Gradient of turbulent eddy frequency grad_sqrt_eddy_period (grad_tg) 3 Gradient of inverse of square root of eddy frequency grad_dissipation_rate (grad_teps) 3 Gradient of turbulence dissipation rate grad_intermittency (grad_tintc) 3 Gradient of turbulence intermittency grad_transition_re_theta (grad_treth) 3 Gradient of critical momentum thickness Reynolds Number grad_viscoelastic_stress (grad_vest) 18 Gradient of viscoelastic stress grad_mesh_displacement (grad_mesh_disp) 9 Gradient of mesh displacement vector grad_mesh_velocity (grad_mesh_vel) 9 Gradient of mesh velocity vector volume (vol) 1 Nodal volume strain_rate_invariant_2 (strain_i2) 1 Second invariant of the strain rate tensor velocity_magnitude (vmag) 1 Magnitude of the velocity vector vorticity (vort) 3 Vorticity cfl_number (cfl) 1 Element-integrated CFL number density (dens) 1 Density viscosity (visc) 1 Viscosity material_viscosity (mat_visc) 1 Molecular viscosity gravity (grav) 3 Gravity specific_heat (cp) 1 Specific heat conductivity (cond) 1 Conductivity field_diffusivity 1 Field diffusivity field_source 1 Field source material_conductivity 1 Material conductivity total_pressure (tot_pres) 1 Total pressure heat_source (heat_src) 1 Heat source turbulence_y (turb_y) 1 Turbulence distance to wall turbulence_y_plus (turb_yp) 1 Turbulence y+ des_length (deslen) 1 Length scale for DES turbulence model running_ave_velocity (ora_vel) 3 Running average velocity running_ave_pressure (ora_pres) 1 Running average pressure running_ave_temperature (ora_temp) 1 Running average temperature running_ave_field (ora_field) nFields Running average field values. For multi_field = levelset and multi_field = algebraic_eulerian, the field values correspond to running average volume fractions, and are named as running_ave_volume_fraction-"fieldname". running_ave_species (ora_spec) nSpecs Running average species running_ave_eddy_viscosity (ora_eddy) 1 Running average eddy viscosity running_ave_kinetic_energy (ora_tke) 1 Running average turbulence kinetic energy running_ave_eddy_frequency (ora_tomega) 1 Running average turbulence eddy frequency running_ave_sqrt_eddy_period (ora_tg) 1 Running average inverse of square root of eddy frequency running_ave_dissipation_rate (ora_teps) 1 Running average turbulence dissipation rate running_ave_intermittency (ora_tintc) 1 Running average of the turbulence intermittency running_ave_transition_re_theta (ora_treth) 1 Running average of the critical momentum thickness Reynolds number running_ave_mesh_displacement (ora_mesh_disp) 3 Running average mesh displacement running_ave_viscoelastic_stress (ora_vest) 6 Running average viscoelastic stress residual_velocity (onr_vel) 3 Residual of momentum equations residual_pressure (onr_pres) 1 Residual of continuity equation residual_temperature (onr_temp) 1 Residual of temperature equation residual_eddy_viscosity (onr_eddy) 1 Residual of turbulence equation residual_kinetic_energy (onr_tke) 1 Residual of turbulence kinetic energy equation residual_eddy_frequency (onr_tomega) 1 Residual of turbulence eddy frequency equation residual_sqrt_eddy_period (onr_tg) 1 Residual inverse of square root of eddy frequency residual_dissipation_rate (onr_teps) 1 Residual of turbulence dissipation rate residual_intermittency (onr_tintc) 1 Residual of the turbulence intermittency residual_transition_re_theta (onr_treth) 1 Residual of the critical momentum thickness Reynolds number residual_mesh_displacement (onr_mesh_disp) 3 Residual of mesh displacement equations error_estimator_volume (oee_vol) 1 Volume error_estimator_velocity (oee_vel) 3 Error estimate of momentum equations error_estimator_pressure (oee_pres) 1 Error estimate of continuity equation error_estimator_temperature (oee_temp) 1 Error estimate of temperature equation error_estimator_eddy_viscosity (oee_eddy) 1 Error estimate of turbulence equation error_estimator_tau_velocity (oee_tau_vel) 1 Error estimate of least-squares metric for continuity equation error_estimator_tau_pressure (oee_tau_pres) 1 Error estimate of least-squares metric for momentum equations error_estimator_tau_temperature (oee_tau_temp) 1 Error estimate of least-squares metric for heat equation error_estimator_tau_eddy_viscosity (oee_tau_eddy) 1 Error estimate of least-squares metric for turbulence equations time_ave_error_volume (oae_vol) 1 Time-averaged volume time_ave_error_velocity (oae_vel) 3 Time-averaged error estimate of momentum equations time_ave_error_pressure (oae_pres) 1 Time-averaged error estimate of continuity equation time_ave_error_temperature (oae_temp) 1 Time-averaged error estimate of temperature equation time_ave_error_eddy_viscosity (oae_eddy) 1 Time-averaged error estimate of turbulence equation time_ave_error_tau_velocity (oae_tau_vel) 1 Time-averaged error estimate of least-squares metric for continuity equation time_ave_error_tau_pressure (oae_tau_pres) 1 Time-averaged error estimate of least-squares metric for momentum equations time_ave_error_tau_temperature (oae_tau_temp) 1 Time-averaged error estimate of least-squares metric for heat equation time_ave_error_tau_eddy_viscosity (oae_tau_eddy) 1 Time-averaged error estimate of least-squares metric for turbulence equation time_ave_velocity (ota_vel) 3 Time-averaged velocity time_ave_velocity_regular (ota_vel_reg) 3 Time-averaged non-conservative velocity time_ave_pressure (ota_pres) 1 Time-averaged pressure time_ave_pressure_square (ota_pres_sqr) 1 Time-averaged square of pressure surface_area (osf_area) 1 Surface area surface_mass_flux (osf_mass) 1 Surface mass flux surface_momentum_flux (osf_mom) 3 Surface momentum flux surface_traction (osf_trac) 3 Surface traction surface_moment (osf_moment) 3 Surface moment surface_convective_temperature_flux (osf_conv_temp) 1 Surface convective temperature flux surface_heat_flux (osf_heat) 1 Surface heat flux radiation_area (orf_area) 1 Radiation area radiation_heat_flux (orf_heat) 1 Radiation heat flux radiation_mean_radiant_temperature (orf_mr_temp) 1 Radiation mean radiant temperature solar_area (oqf_area) 1 Solar area solar_heat_flux (oqf_heat) 1 Solar heat flux where nSpecs is the number of species as given in the EQUATION command in the input file. The output fields for time_ave_velocity_square and time_ave_stress are xx, yy, zz, xy, yz, and zx. The output fields for gradient variables are, for example, ux, uy, uz, vx,....
- verbose or v (integer)
- Set the verbose level for printing information to the screen. Each higher verbose level prints more information. If verbose is set to 0, or less, only warning and error messages are printed. If verbose is set to 1, basic processing information is printed in addition to warning and error messages. This level is recommended. verbose levels greater than 1 provide information useful only for debugging.
Examples
acuOdb -pb channel -ts 5
problem= channel
time_steps= 5
acuOdb
