AcuTransTrace
Translate acuRunTrace solution binary record output to other formats.
acuTransTrace [options]
acuRunTrace Post-Processing Program
acuTransTrace -pb channel -to fieldview -fvopt streamline,steady
problem = channel
translate_to = fieldview
fieldview_options = streamline,steady
acuTransTrace
AcuTransTrace option | EnSight | FieldView | Endstats | Poincare Table | AcuDisplay | Query |
streamlin | no | yes | yes | no | yes | yes |
time_cut | yes | yes | yes | no | yes | yes |
poincare | yes | yes | yes | yes | yes | yes |
acuTransTrace: Outputs are:
acuTransTrace: velocity_magnitude
acuTransTrace: element_id
acuTransTrace: element_set_id
acuTransTrace: marker
acuTransTrace: x_length
acuTransTrace: y_length
acuTransTrace: z_length
acuTransTrace: x_velocity
acuTransTrace: y_velocity
acuTransTrace: z_velocity
Note that particle position is required by all the translation formats and therefore is not listed. Particle time is only listed for the poincaretable and Poincare EnSight formats; it is required by all the other formats and therefore not listed for those.
For a general description of option specifications, see Command Line Options and Configuration Files. See below for individual option details.
- help or h (boolean)
- If set, the program prints a usage message and exits. The usage message includes all available options, their current values and the source of their current values.
- problem or pb (string)
- The name of the problem is specified via this option. This name is used to build internal file names and to generate output files.
- working_directory or dir (string)
- All internal files are stored in this directory. This directory does not need to be on the same file system as the user-supplied input files.
- run_id or run (integer)
- Number of the AcuSolve run used by the trace run. If run_id is set to 0, this option is ignored. This parameter needs to explicitly set only in rare cases.
- trace_run_id or trun (integer)
- Number of the AcuRunTrace run to translate. If trace_run_id is set to 0, the last trace run in the working directory is assumed.
- translate_to or to (enumerated)
- Translate the AcuRunTrace output to this format:
- query
- Print information about available AcuRunTrace result types.
- ensight
- Translate to EnSight Gold format.
- fieldview
- Translate to FieldView format.
- endstats
- Report the end point statistics, that is, the reasons the trace of each particle ended.
- poincaretable
- Translate Poincare results into an AcuTraceClassic style Poincare table.
- num_threads or nt (integer)
- Number of threads to use. Note that MPI is not available, so there is no np option. This option is available only with translate_to = ensight.
- fieldview_options or fvopt (string)
- A comma separated list of FieldView translation options. The list may include:
- streamline
- Use streamline (pathline) results if available.
- time_cut
- Use timecut results if available.
- poincare
- Use Poincare results if available.
- pseudotc
- Use pseudo timecut values for time with Poincare results.
- ascii
- Convert to FieldView ASCII Particle Path format. This format is for use with steady-state flows and is a synonym for steady.
- binary
- Convert to FieldView BINARY Particle Path format. This format is for use with transient flows and is a synonym for unsteady.
- ensight_options or ensopt (string)
- A comma separated list of EnSight translation options. The list may include:
- time_cut
- poincare
- pseudotc
- Use pseudo timecut value for time with Poincare results.
- binary
- Write binary EnSight files.
- ascii
- Write ASCII EnSight files.
- nomesh
- Do not write the AcuSolve mesh file. This can be a run time savings if the mesh file exists and is current.
- end_stat_options or endopt (string)
- A comma separated list of end point statistics translation options. The list may include:
- streamline
- time_cut
- poincare
- acudisplay_options or acdopt (string)
- A comma separated list of AcuDisplay translation options. The list may include:
- streamline
- time_cut
- poincaretable_options or ptbopt (string)
- A comma separated list of Poincare table translation options. The list may include:
- ordered
- Sort the table by seed number and Poincare plane number. This can take a while.
- unordered
- Do not sort the table.
- verbose or v (integer)
- Set the verbose level for printing information to the screen. Each higher verbose level prints more information. If verbose is set to 0, or less, only warning and error messages are printed. If verbose is set to 1, basic processing information, including the output variables found, is printed in addition to warning and error messages. This level is recommended.
Examples
acuTransTrace -to query
acuTransTrace: -----------------------------------------------------------------
acuTransTrace: Date = Tue Aug 30 20:54:35 2011
acuTransTrace: Problem = mixer
acuTransTrace: Flow Run = 1
acuTransTrace: Trace Run = 8
acuTransTrace: Streamline trace type = Available
acuTransTrace: Timecut trace type = Available
acuTransTrace: Poincare trace type = Available
acuTransTrace: Hostname = COOT
acuTransTrace: Platform = Whistler 5.1 i686
acuTransTrace: Machine = WIN
acuTransTrace: Release = 1.8a
acuTransTrace: Release date = Aug 30 2011
acuTransTrace -to query -trun 1
acuTransTrace: Poincare trace type = Unvailable
then streamline and timecut results are available for trace_run_id = 1, but Poincare results are not.
(hit_number - 1) * number_of_planes + plane_number
acuTransTrace -to fieldview -fvopt steady,streamline
acuTransTrace -to fieldview -fvopt ascii,streamline
acuTransTrace -to fieldview -fvopt steady,time_cut
acuTransTrace -to fieldview -fvopt unsteady,time_cut
acuTransTrace -to fieldview -fvopt binary,time_cut
acuTransTrace -to fieldview -fvopt poincare
acuTransTrace -to fieldview -fvopt poincare,pseudotc
acuTransTrace -to ensight -ensopt ascii,time_cut
# EnSight Gold Case file for particle
# Problem : mixer
# Generated by : acuTransTrace
# Release : 1.8a
# Release date : Aug 30 2011
# Date : Tue Aug 30 18:35:21 2011
FORMAT
type: ensight gold
GEOMETRY
model: ENSIGHT.DIR/mixer.mesh.geo
measured: ENSIGHT.DIR/mixer.mgeo.*****
VARIABLE
scalar per measured node: time ENSIGHT.DIR/mixer.time.*****
TIME
time set: 1
number of steps: 2
filename numbers: 1 2
time values: 0 0.0001
Time cut or Poincare output can be converted to EnSight format. Since a particle may hit a Poincare plane multiple times, a given seed can appear multiple times in a single EnSight file. If the pseudotc option is used, however, Poincare plane numbers converted to time values, and so a seed does only appear once in a single EnSight file. In the case of multiple plane hits, the pseudo time cut value is again given by the expression described above in the FieldView discussion.
acuTransTrace -to ensight -ensopt poincare,binary (or ascii)
acuTransTrace -to ensight -ensopt poincare,pseudotc,binary (or ascii)
For endstats format, AcuTransTrace creates a text file problem.trace.end. The file consists of a table,
one line per particle, listing the possible reasons why the particle trace ended.
acuTransTrace -to endstats -endopt poincare
Column number | Column heading | Description |
1 | Seed | Global seed number |
2 | X | X coordinate of particle position |
3 | Y | Y coordinate of particle position |
4 | Z | Z coordinate of particle position |
5 | Time | Particle time |
6 | Speed | Magnitude of particle velocity |
7 | Lx | X coordinate of particle stretch vector, or 1 if no stretch equation |
8 | Ly | Y coordinate of particle stretch vector, or 0 if no stretch equation |
9 | Lz | Z coordinate of particle stretch vector, or 0 if no stretch equation |
10 | ElmId | Element set ID number (1-based) |
11 | ElemId | Element ID (1-based) |
12 | Out | 1 if particle left domain through an outflow face, 0 otherwise |
13 | Wall | 1 if particle stopped at a wall surface; 0 otherwise |
14 | Node | 1 if particle stopped at a wall node; 0 otherwise |
15 | Ssi | 1 if particle stopped at an interface surface; 0 otherwise |
16 | Rff | 1 if particle stopped at a reference frame boundary; 0 otherwise |
17 | Time | 1 if particle time exceeded maximum trace time; 0 otherwise |
18 | Tcut | 1 if particle hit the last time cut and only time cut output requested; else 0 |
19 | Segs | 1 if number of particle segments exceeds maximum; 0 otherwise |
For columns 12 to 19, more than one column can contain a "1" because the table lists all the possible reasons why the particle trace ended. Note that 1 is not a possible value for Rff if the AcuRunTrace FLOW_FIELD type is pseudotransient.
- global particle number
- Poincare plane number
- x,y,z coordinates of the intersection of the particle path line with the plane
acuTransTrace -to poincaretable
acuTransTrace: time
then columns 6-11 of problem.pps are time, the element set and element IDs, and the particle velocity.
