rotate()
Rotate the camera by special degrees in special directions.
Usage
vis.rotate( dir, angle = 45 )
dir (string)
The desired direction. Valid values are x+, +x, xplus, y+, +y, yplus, z+, +z, zplus, x-, -x, xminus, y-, -y, yminus, z-, -z and zminus in case insensitive manor.
angle (integer)
Degree of rotation.
Return Value
None
dir should be valid.
angle should be integer.
This routine rotates the camera by special degrees given by angle in special directions given by dir. For example,
vis.rotate( dir ="x+", angle = -20. )
