udfCheckNbcNumUsrVals()
Check the number of user values given in the input file.
udfCheckNbcNumUsrVals( udfHd, nUsrVals ) ;
AcuSolve User-Defined Nodal Boundary Condition
udfHd
The opaque handle (pointer) which was passed to the user function.
nUsrVals (integer)
Number of user values that the function expects.
Return Value
None.
This routine verifies that the number of user values supplied in the input file is the same as the second argument. If it is not, an error message is issued and the solver exits. For example,
udfCheckNbcNumUsrVals( udfHd, 2 ) ;
This routine expects a valid udfHd.
